Cylindrical Panorama outputs
I need to create a cylindrical panorama rendering (Format JPG) 540px height…do I need a plug-in? …We are rendering an animation and one of the shots is a camera with an animated target paning around…It’s taking for ever do it…so I was wonderings if the panorama can save us a lot time.
Thanks,
Fernando
You could use the VrayDomeCamera to render a hemispheric picture to use as an environment to render a rotating camera
You can also use a standard max cam and then in the vray:camera rollout in the render panel you can choose a suitable option there.
well, I made a HDRI panorama with a box projection…I put it as environmental map, after that I animated the target camera…when I move the camera the background change in my viewport but when I run the animation the frames are exactly the same…the background don’t change acording with the camera…any idea?
The environmental map is a Vray HDRI.
Thanks,
Fernando
Sounds like its mapped in “screen” mode.
It wasn’t a screen mode…some problem with Max…when I loaded file again it worked fine!! …the only problem is the quality of the HDRI, it doesn’t look sharp enought, but the idea works.
Thanks,
Fernando
