De-Noise of render elemnts
Does the De-Noise work on render elements, so we can re build the beauty in comp?
Not yet, but should be implemented in 1.5
Sad :frowning:
Any idea when that may be :smiley: ?
You can watch the progress here: Daily Builds 1.5 - Corona for 3ds Max :: Previews (Daily Builds) - Chaos Forum and check the roadmap here Trello
And of course with a FairSaaS or Box with Subscription license you can download the daily builds to try it out as it progresses, but do remember this is a use at your own risk scenario as this is in-development software, not a finished release! And yes, it does replace your current install, you can’t have 1.4 release and 1.5 daily build running alongside each other (though you can do stuff like install 1.5 daily on Max 2016 and keep 2017 running with the 1.4 release for production work, or similar).
Thanks for the reply!
Actually there are ways to do this. :smiley:
https://coronarenderer.freshdesk.com/support/solutions/articles/5000577837
maru, shouldn’t this line be updated to include also “CoronaLib_Release.dll” file?
You are probably right… Thanks!
