hi!
Is there a possibility to temporarily deactivate an render element? The AO takes long to render and I would like to just deactivate for test rendering without deleting it.
cheers
fikret
hi!
cheers
fikret
Heh I asked that like 2 days ago o.O
Can Vray maybe take the Max Enabled tick instead of overriding it with his own or its too max bound ?
Could save some duplicate threads o.O
Thank you Yavor for the answer.
But turning the AOV off with vrayVFB doesnt prevent it from being calculated. And I would need the other AOVs, so turning off Elements Active doesnt help.
That is strange - in my simple tests turning off with the vrayVFB checkbox works as expected.
Can you share a simplified scene in which it doesn’t?
Yavor
You are right it works, thank you Yavor!
this might also help:
O man you are a legend! Thanks!
I spend around 1-2h the other day on dealing with state sets and render elements. This would’ve been 5 min job with this script! Thanks buddy!
you can actually create a scripted state which turns off render elements per state. But really, I would love to have this option working with state sets in regular render elements tab as it should.
Thank you very much Henning, thats a very useful script!
I take this back, actually state sets now support vray vfb on / off by default!
