Is there a way to flag on/off several selected Render Elements at once in the Render Settings window?
Like shift+select+Y/N or similar?
Thanks,
s
Thanks,
s
Not that I know, but I’ve come to love L Pass Manager in the last few weeks: http://www.scriptspot.com/3ds-max/scripts/l-pass-manager
There you can very quickly select/deselect elements per pass.
oops, this was a question for the Maya forum.
Thanks,
s.
I don’t think so, but I’ll put it down as a feature request.
If we can create some “set” of renderElements (like mentalRay), it would be great.
I modified Dmitry’s suggestions in another thread to make this decent workaround.
s.
//selects all vRay Render Elements and pops them to the attr spreadsheet window for fun toggling.
string $vRayElem[]= `ls -type VRayRenderElement`;
select -r $vRayElem;
SpreadSheetEditor;
You can select the RE in the outliner if the DAG object only is off. once selected you can use the spreadsheet window to switch them on/off.
Yannick
What I usually do is have a separate maya file which only has render elements and a control node. I know ahead of time which render elements should be on/off on which render layers. Then I connect the control node with enable switch to those layers, for example for beauty, utility, custom only specific layers get enabled.
