Debug node
Coming from max the new debug feature in vray is super handy, so i wonder how long will it take to implement it in Houdini? Ideally it would work like Renderman and Mantra, via the debug button in each shading node… This way imo is way superior to the way it works in max.
There is currently no UI in VFB, but it’s implemented under ROP → Renderer → Options → “Material Override”. Check Mode parameter there.
I’ll need more info of how it works there.
Here’s what i mean: Imgur: The magic of the Internet
Do you think it’s possible?
Currently you can drag and drop any node on your object and get the same behavior.
I was talking to one of the devs about this after your post - it would be cool if we could use this flag so you don’t have to do the drag - dropping which stays behind after an IPR session is finished. But @bdancer rightly pointed out that multiple nodes can have the Debug flag enabled, in which case - what do we do ? I just checked with Renderman - seems like they only consider the first node which has this flag applied, and consecutive nodes are ignored.
I think the “top” flag (node closer to the shader) should have priority, that’s one of the things i don’t like in the current implementation in renderman.. let’s say i have a texture > dirt > shader diffuse color. If i flag the texture node it isolates that one, and if i flag the dirt after that it should should the dirt one.. and so on.
Moriah, VOP debug flag support is implemented in the nightlies. Please, check if it works as you expect.
