decent size rendering having some problems doing anything
I’ve switched to vray frame buffer,
turned Off use memory frame buffer and turned on the save to file feature.
the render is 10240x7680.
I set max resolution to 16x12
I hit render…Max disappears instantly without even thinking. It’s just Gone
are you rendering from a saved IRmap?
