Vray frame buffer problem
I have hi poly scene so I use Vray frame buffer to conserve memory.
First I set resolution 100x100 in 3dsmax and than in vray frame buffer I set 2000x2000 and everything renders ok but when I render using DR, 3dsMax always renders using his resolution and thats 100x100 in this case.
Any sugestions.
DR apparently doesn’t like Vray Frame buffer and you have to use the Max frame buffer. Can’t test this myself as I have yet to get DR working, which is getting really frustrating!
rpc212
