Hi, newest versions of Vray shows in blue if the default value has been changed, but it doesnt tell you which was the default value (until you use the option to reset all to defaults), right clicking the spinner puts minimum value, in newer versions of Max you can use keyboard combinations to set it to default values and even set different values as default ones, but if I dont use max 25 (which I think it was the version that introduced that controls) could we have the default value when right clicking the spinner like in Corona?
Which 3ds Max version are you using? Those keyboard shortcuts are available in 2023, too.
Im with Max 2026, but as I mentioned, not many people know it and it would be very simple to just right click into the spinner to get back default value like Corona and not the minimum value which most cases is 0.
I mentioned that in the original message but most people doesnt know this options exists, for me it would be more practical to use a right click in the spinner instead of ctrl+right click, which I always confuse with shift or alt combination.
We are looking for similar to the 3ds Max behavior, so no further changes are planned.
