With tyflow we can write an unlimited number of data channels that can be exported. Will be great if phoenix can read this data channels and assigned to any emitter value.
Yess, this would be really cool!
I think I can add this to the discharge modifiers - for example your particle age setup from the other thread could be achieved using a discharge modifier over the smoke as well, where the discharge modifier uses the particle age and you can draw a curve with how the smoke emission is reduced over time, like this:
If I expose any custom particle cannels in the dropdwon, this should allow for modifying the Source values by custom channels.
Does this sound like it would work for what you need?
Cheers!
