Deformed geometry
Hi everyone.
I’m having some issues whith Rhino 6.
When I launch Enscape, all the geometries seem deforms.
Any clue why this happend?.
Some info about the model:
  • Units: Meters
  • All the geometry were created in Revit 2020 and imported into Rhino.
  • It keep the same position from 0,0,0 (way far from the origin)
thanks for your help.
Regards
@veas87 , welcome to our forum.
In this case, does it help if you set the Units in your Rhino to “Centimetres”, as this is the unit we recommend to be used for Enscape in the first place. Otherwise if that doesn’t help, is there a chance you could share the project with me? And, can you perhaps also send me a screenshot of how the project looks in Rhino please? :slight_smile:
Thank you in advance.
Thanks Demian for your help.
I moved the entire model to the Rhino’s origin, and it solved (Previously was with the georeferencial position given by Revit).
It wasn’t needed to change the model units.
Having the project 6310 kilometres away from the origin is indeed quite a distance which can cause such issues - glad to hear you were able to resolve it!
