Denoiser not working in older scenes
Hi I get this problem quite often.
I open an older scene prior to when denoiser was introduced and add denoiser in elements.
Hit render but no denoiser elements and effects are rendered.
To get the denoiser to work I have to merge everything into a fresh scene.
Anyone else have this problem?
Maybe it’s the same problem as mine where denoiser doesn’t work on low camera f and shutter speed settings.
Guys at Chaos also suggested to increase the post effect rate (under settings tab). Default is 10. In my case that didn’t help, so they also suggested to use 4-6 f number and shutter speed 40-80. That helped in my case.
There is a big issue with low F number. In some cases in low light interior VRay sample dark areas really badly. With higher F number its ok.
I’m pretty sure I have used the same camera when merged into the fresh scene. I will look into that though…
f number in particular scene is 8. So rather high actually
Do you get any warnings in the log ? One possible reason for the denoiser not to work on old scenes is the old adaptive sampling method.
You can change it with the following MAXScript command:
renderers.current.twoLevel_adaptiveMethod=1
Yavor
Im using rt gpu so adaptive sampling should not matter. I wil look in the log
