Denoising doesn't work in full rendering
Hi guys,
In the new Corona 12 Daily Build (17 Jan 2024), none of the Denoising realtime options work in full rendering process, in IR is perfectly fine.
Please let me know if is a bug or not.
Thanks,
Dionysios -
Could you add some more information please - which version of Max? Also do you mean that neither Intel or NVIDIA denoisers are working in a final render? And you have set the chosen denoiser for final render in the Scene tab of the Render Setup, and not just the denoiser for realtime in the Performance tab? (Setting the second but leaving the first to None will mean no denoising in final renders).
Hi, I am not able to repro this on my end using the same build with 3ds Max 2024.2. Can you give us some more info with repro steps so we can try reproducing the same issue on our end?
Hi guys and excuse me for the delay to answer.
I still use 3ds Max 2023 perfectly updated and I confirm that neither Nvidia or Intel is working in full render mode.
Obviously I turned on the Denoise option in the Render Setup as I do always so this is not the issue. With the previous Daily Build everything was fine.
It’s not scene related as with a simple plane and teapot it does the same… :frowning:
I don’t know what other info give to you for now. I am really sorry.
Tested in Max 2023.3.4 Security Fix, with latest daily, and both Intel and NVIDIA working here in final render, set from the Scene tab. Any error messages? Is the “Denoising” checkbox able to be checked and unchecked in the VFB on completion?
That’s crazy! :smiley:
Wht’s wrong with it? Maybe I need to install again the Daily Build?
I would try reinstalling after reverting to the previous daily (which I think you have already done), just to see. Do let us know if you get any errors, and if the Denoising checkbox can be checked on and off after a render is complete (this lets us know if denoising actually ran or not, it will be greyed out if there was no denoising). If time allows, a video of the process, from setting the chosen denoiser to rendering a scene, could help. You could send in any scene that has the problem too, so we can have a look through the settings and test that specific scene here (even the plane and teapot scene, if that is giving the same problem :smiley: )
I confirm that:
previous chaos-corona-12-3dsmax-daily-2024-01-05 build works perfectly while the latest chaos-corona-12-3dsmax-daily-2024-01-17 doesn’t.
At this point I don’t know what’s wrong from my part. :frowning:
maybe you can send a ticket to us and we can look into it for you.
Submit a support ticket -
https://support.chaos.com/hc/en-us/requests/new
