Some background - currently working on a animated short. Using VRay Next (latest version- hotfix 1) with Maya 2017 (update 3)
Rendering frames via MayaBatch (single machine for now). Experiencing an issue where if a sequence is re-rendered via MayaBatch there are differences in brightness in the rendered images.
eg - yesteday submitted a 80 frame sequence. After 41 frames the batch process was cancelled to resume work on other tasks (renders are happening over night). Today re-submitted the last 39 frames. Last 39 frames all have a shift in brightness compared to the first 41. This has happened a couple times on other shots also and has required re-rendering entire sequences.
Using default settings for the most part
Bucket Sampler: 1/32 Min Shading rate: 6
BF/LC 3000, retrace 8
Color Maping Mode: Don’t Affect Colors, Only Adaptation
Cache Bitmap and Geometry Plugins both switched off (assume this is not required in Batch Rendering?)
All maps/HDRI’s are being loaded in from a network location. No errors to suggest anything is not being loaded.
Renders are otherwise coming out smooth/flicker free.
Any pointers would be much appreciated.
thanks
