Disable Grasshopper Preview
I know this is actually presented as a feature, but is there a way to disable the automatic preview of Grasshopper Geometry in V-Ray?
I would like much more if it was off by default, but could be enabled with a simple component, a bit like custom preview.
I have a file where I need to see the Grasshopper geometry in the viewport, but not in the render and always switching back and forth is a bit tedious.
Thanks for any hints on how to disable it.
You can use the Visibility node in the V-Ray Geometry component.
1 is visible 0 is invisible.
