On the latest release of Enscape I cannot get the Enscape window to reflect the view in the Sketchup window, wondering if someone else is having the same issue, and yes I have the “Sincronize” view on
Octavio
Octavio
… I also have this problem - tried to fix it yesterday for hours, without success.
I need a material ID layer for almost every project. Unfortunately this native Enscape layer is qualitatively too useless (what I will report about in detail later). So I produce this material ID layer in another tool (Render[In]).
All renderer - SkUp camera views are synchronous 100% across all platforms - only exception is Enscape ??
In my case this applies to all Enscapes, including the previous ones. So I hope as well to get this topic settled soon ![]()
I have luck matching views ( on the same computer ) when I press synchronize view, then uncheck it, and hit render.
I am embarrassed a bit
I always confuse the English terms check and uncheck - could someone please make this clear to me?
Ryanfernie, maybe you could add a screenshot of your working setüp, somehow the SkUp-setup side by side to your Enscape setup?
Thanks ! ![]()
@octavio01 , so, you’ve activated our “Synchronize View” functionality, and when you move the camera in SketchUp, there is no change in Enscape itself? The synchronization is basically turned off?
@EGIESTO , you’ve turned on “Synchronize View” as well, and once you switch between views in SketchUp, these view changes do not translate into Enscape?
If that is the case, could you please both send us feedback via the Feedback button in your Enscape context menu? Please don’t forget to add your forum name or some other reference into the submission form so that I can connect the report to this thread! ![]()
Please refer to this image:
First picture, “Synchronize Views” is checked = activated, second picture, it’s unchecked = deactivated. ![]()
