displacement problem
Hi
I noticed a bug related to displacement feature.
When You apply a displacement modyfier to one object and after You will extract some faces from the same object Maya freeze forever during the render time. I tried to remove displacement manually from Vray space bar menu from the object it didn’t need it anymore. I tried also to apply different material for the piece displacement wasn’t need, also clear history wasn’t helpfull and any related stuff…
In my opinion before apply displacement be sure to have right object for that , any extracts, cutting faces after will blow and freeze maya during render times…
p.s maya 2011 x64 running on Windows Vista Ultimate , Vray 2.0
cheers
czaps
We can’t reproduce the issue here.
Could you please send us a scene to: vraymaya@chaosgroup.com
Also, please include ethe exact steps for reproducing the problem.
hi Zdravko
I will try to send You the scene tomorrow and see how it goes. I particly solved the problem in my scene for that.
Although it should be more common way to do that in some way maybe…
cheers
czaps
