distance texture with viewport subdiv
Heyho,
when I pipe a distance texture node to the blend amount of a VrayBlendMtl everythings works the way expected.
Now hitting `3` for smooth mesh preview and enabling the render viewport subdivs in the vray render tab the blending disappears (no near value anymore).
When I convert the smooth mesh preview to polys it works and the blend stays where it belongs.
Am I missing something?
Thanks a lot!
Rico
I further just realized that if I plug a vector displacement map (vray water text) into the mesh which is the object to define the distance effect the near color disappears too.
Thank you very much for your feedback.
We’ve made a note about these issues into our system and we will let you know when we have some updates on that matter.
For the moment it is a technical limitation that the distance texture only works with polygonal meshes. We will look into the possibility of supporting other run-time generated geometry types, but I don’t know when it will be done.
Thanks for your feedback … going to stick with mapping so long.
