Hi all
I’m coming from a long background in 3DS Max with V-Ray. I’m getting into using V-Ray with Houdini now. When enabling distributed rendering, I’m getting the following warning:
These files are located on drives in my main server machine. Those drives are shared to the networked and mapped from all render clients with the same letter. In 3DS Max this is no issue. Max and V-Ray just treat the network mapped drives as regular drives, the client machines are able to all see the files, and rendering progresses normally. However, in Houdini, this is not the case. Is there some sort of variable or path I have to set somewhere so V-Ray for Houdini knows to use files from shared drives?
Thank you!
