Distributed rendering in vray SR1, RC1
Hi, just downloaded and installed the new vray sr1 rc1, DR is not working and it is rendering VERY slow.. any ideas whats up with this thing? do i need a new DRSpawner in all the computers?
Re: Distributed rendering in vray SR1, RC1
Works fine here. Fast like allways. Some times duplicate objects cause a slow down, test it per _seldup command.
thanks micha, did you have to reinstall the drspawner in al the salves? if so which one, the same one as the old version?
i installed the rhinosr2 thinking that could be the problem, no luck!
I saw the “Dr without install at slaves and easy update” post.. can you explain this in more detail.
Thanks again!
Best, you take the ASGvis dir from c:/documents and settings … and copy it to the slaves. Than start the spawner at the slaves.
At the master machine, if you go to the Rhino DR options and type in the slave names and press “resolve servers”, did you get a respond? If not, than it could be a network issue.
hello manovo,
I also had much problems with DR in the last versions, can you tell me exactly what is not working? Do the spawners start to render or are they crashing? Are there any error messages or is it just slow?
Andy
Please refer to this topic: Chaos: Industry-leading design and visualization software
Joe has added an additional comment on the issue.
thanks guys, DR is working like a champ!! I just did what Joe suggested on the other post.. and voila!
