Distributed rendering, Main computer Doen't show all proxy.
HI,
I have a very weird issue on many scenes.
No to try debuggind I started a new scene from scratch.
1- juste one Map for models + corona sun sky . Render onmy workstation Alone Ok, Render + Distributed rendering Ok
2- Scene scene + HDri , Render onmy workstation Alone Ok, Render + Distributed rendering Ok
3- Scene scene + HDri + PROXIEs (trees), Render onmy workstation Alone Ok, Render + Distributed rendering Wrong… My Main workstation refuse to show and use proxy?? how is it possible. I know it is my worsktation as render takes some times to run on DR. And Immediatly Proxy does not show up.
IR Is OK, Alone Render Is OK,
All files are on my Network, Stored on a Qnap, All is Ok, acces Is ok, Cable are OK,
All max are up to date, All plus have same version, Corona is 8.2, Max 2022 last SP.
any clues ?
Try Another thing,
To convert Proxy back to mesh.
I only did this on One proxy, the bigger one.
See attachement, errors…
Than I try a different approch, Use only one node at a time.
And all works ok. What ever node I select, Everything is OK.
But If I check more then One, Errors Are Back
Anyone bump into this issue?
Are you getting some errors printed out to the Corona error window or DR logs?
If so, can you tell us what they say?
Rowan
I will restart my debug scene, to see if any thing pop’s up.
So far the only thing we have to do to get it working is have only 1 render node check. It works perfectly. As soon as I check another one, issues/errors happend again.
Exact same thing on my associate workstation, same error One node Ok, two or more errors.
So I take some time to try.
All 3dsmax 2022 are update with last SP and Security
All forest / railclone / corona 8.2 / bercon maps / atiles/ anima are update all same version.
All pc have access to Shared network
No error on Corona interface, Nothing pops’up
DR log seems ok
Handshake: 0init0Max2022Corona Camera0010 0 0 06500 365675734294a30e25c2589885a1da7a1b788 (Hotfix 2)255.255.255.255
2022-09-22 15:59:49 Saving incoming scene to C:/Users/mecagirl/AppData/Local/CoronaRenderer/DrData/received_scene_313627724.max
2022-09-22 16:00:12 Downloaded scene: 580 M bytes in 23 s
2022-09-22 16:00:14 Render for connection 1 started
2022-09-22 16:00:22 Received sampling focus mask (region 0 0 6500 3656)
2022-09-22 16:01:22 Started EXR dump (30 688 209 bytes, filename: C:/Users/mecagirl/AppData/Local/CoronaRenderer/DrData/dump6096.exr)
2022-09-22 16:01:23 Finished EXR dump after 0 s
2022-09-22 16:01:23 Received sampling focus mask (region 0 0 6500 457)
2022-09-22 16:02:23 Started EXR dump (71 044 553 bytes, filename: C:/Users/mecagirl/AppData/Local/CoronaRenderer/DrData/dump6097.exr)
2022-09-22 16:02:25 Finished EXR dump after 1 s
2022-09-22 16:02:25 Received sampling focus mask (region 0 457 6500 914)
2022-09-22 16:03:23 Got a message from remote: terminate_soft
2022-09-22 16:03:23 Sending command to slave: 0terminate_soft
2022-09-22 16:03:25 Started EXR dump (581 M bytes, filename: C:/Users/mecagirl/AppData/Local/CoronaRenderer/DrData/dump6098.exr)
2022-09-22 16:03:25 Slave 3ds Max ended render
2022-09-22 16:03:43 Finished EXR dump after 17 s
2022-09-22 16:03:43 DR is finished
2022-09-22 16:03:43 Ready for new connection
2022-09-22 16:06:34 Accepted remote connection from 192.168.1.101
2022-09-22 16:06:34 Started connection 2
2022-09-22 16:06:34 Handshake: 0init0Max2022Corona Camera0010 0 0 06500 36564ab6258869ee365837fd722cc5f601818 (Hotfix 2)255.255.255.255
2022-09-22 16:06:34 Saving incoming scene to C:/Users/mecagirl/AppData/Local/CoronaRenderer/DrData/received_scene_480659718.max
2022-09-22 16:07:02 Downloaded scene: 580 M bytes in 28 s
2022-09-22 16:07:03 Received sampling focus mask (region 0 0 6500 3656)
2022-09-22 16:07:04 Render for connection 2 started
2022-09-22 16:08:06 Started EXR dump (36 653 277 bytes, filename: C:/Users/mecagirl/AppData/Local/CoronaRenderer/DrData/dump1094.exr)
2022-09-22 16:08:08 Finished EXR dump after 1 s
2022-09-22 16:08:08 Received sampling focus mask (region 0 2742 6500 3199)
Corona Log too:
2022-09-22 16:07:05 Parsing scene
2022-09-22 16:07:05 ====RENDER STARTED====
2022-09-22 16:07:05 Core build timestamp: Jun 27 2022 13:49:09
2022-09-22 16:07:15 Geometry evaluation and parsing of object ‘MT22_Acer_platanoides_01_01’ took: 9070
2022-09-22 16:07:15 Estimated time left: 0:00:06
2022-09-22 16:07:16 Geometry evaluation and parsing of object ‘MT13_Cytisus_scoparius_01_04’ took: 10751
2022-09-22 16:07:17 Geometry evaluation and parsing of object ‘MT16_Fagus_sylvatica_01_03_’ took: 11546
2022-09-22 16:07:17 Geometry evaluation and parsing of object ‘MT22_Quercus_ilex_01_01_’ took: 11620
2022-09-22 16:07:17 Geometry evaluation and parsing of object ‘MT13_Cytisus_scoparius_01_06’ took: 11890
2022-09-22 16:07:19 Geometry evaluation and parsing of object ‘MT22_Quercus_ilex_01_02_’ took: 13310
2022-09-22 16:07:20 Geometry evaluation and parsing of object ‘MT22_Quercus_ilex_01_06_’ took: 14845
2022-09-22 16:07:20 DR slave received sampling mask, region 0 0 6500 3656
2022-09-22 16:07:21 Parsing scene took 15.9720011 seconds
2022-09-22 16:07:21 Calculating displacement
2022-09-22 16:07:24 Processing displacement of object ‘plã_tre___plaques_de_plã_tre’ took: 3051
2022-09-22 16:07:26 Processing displacement of object ‘enduit___blanc_nature’ took: 4123
2022-09-22 16:07:26 Processing displacement of object ‘env_routepieton’ took: 4129
2022-09-22 16:07:26 Processing displacement of object ‘env____asphalte_clair’ took: 4434
2022-09-22 16:07:26 Processing displacement of object ‘bois___pin_granuleux_horizontal’ took: 3934
2022-09-22 16:07:27 Processing displacement of object ‘env_cours’ took: 4547
2022-09-22 16:07:28 Processing displacement of object ‘MT13_Cytisus_scoparius_01_06’ took: 6390
2022-09-22 16:07:28 Processing displacement of object ‘bardage___clair’ took: 6556
2022-09-22 16:07:29 Processing displacement of object ‘bois___pin_granuleux_horizontal’ took: 7329
2022-09-22 16:07:30 Processing displacement of object ‘MT13_Cytisus_scoparius_01_04’ took: 7634
2022-09-22 16:07:30 Processing displacement of object ‘MT16_Fagus_sylvatica_01_03_’ took: 3824
2022-09-22 16:07:30 Processing displacement of object ‘env_google’ took: 8395
2022-09-22 16:07:31 Processing displacement of object ‘MT22_Quercus_ilex_01_06_-mesh001’ took: 9552
2022-09-22 16:07:31 Processing displacement of object ‘MT22_Quercus_ilex_01_02_’ took: 9622
2022-09-22 16:07:31 Processing displacement of object ‘MT22_Quercus_ilex_01_06_’ took: 9777
2022-09-22 16:07:31 Processing displacement of object ‘MT22_Quercus_ilex_01_01_’ took: 7526
2022-09-22 16:07:31 Processing displacement of object ‘env_herbe01’ took: 7870
2022-09-22 16:07:32 Processing displacement of object ‘env_bordure01’ took: 10162
2022-09-22 16:07:32 Computing displacement took 10.1700001 seconds
2022-09-22 16:07:32 Preparing geometry
2022-09-22 16:07:36 Embree: memory usage: 6,1 GB. Total embree build time is 4404ms, top level commit took: 0ms. There are 51 embree geometry groups, 51 instances, triangle objects: non-animated=51/animated=0, hair objects: non-animated=0/animated=0, custom objects: non-animated=0/animated=0, particle objects: non-animated=0/animated=0
2022-09-22 16:07:36 Embree scene building took: 4404
2022-09-22 16:07:36 Preparing geometry took 4.57500029 seconds
2022-09-22 16:07:36 Preparing lights
2022-09-22 16:07:36 Preparing lights took 0 seconds
2022-09-22 16:07:36 Computing sec. GI
2022-09-22 16:07:37 Estimated time left: 0:00:00
2022-09-22 16:07:37 Computing secondary GI took 1.1400001 seconds
2022-09-22 16:07:37
2022-09-22 16:07:37
2022-09-22 16:07:37 Rendering started…
2022-09-22 16:07:37 Rendering initial pass
2022-09-22 16:08:08 DR slave received sampling mask, region 0 2742 6500 3199
2022-09-22 16:08:38 Rendering pass 2
2022-09-22 16:09:08 Rendering initial pass
2022-09-22 16:09:12 DR slave received sampling mask, region 0 3199 6500 3656
2022-09-22 16:09:34 Rendering pass 2
The only reason I can think of why a proxy is not rendered is that it cannot be read from the disk.
What happens if you move the proxy file to another location? (local disk, or another network folder)
Could it be some access rights? Maye try running 3ds Max as administrator on the master machine?
If you like Weirdness, here is the video : Smash
Plase skip forward as it is a realtime Unedited video
Hi, It defenitly seems a files acces error.
I Copied all file to a simple PC with folder acces for every Render node, and all works Ok , many time.
Next Stop Qnap Technical support. To bad for a 2000+€ Nas…
Keep you update If problem solve.
Are you using mapped network drives or UNC paths?
3ds max has a problem with mapped network drives: https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-assign-a-path-using-the-Universal-Naming-Convention-UNC.html
Thanks,
Rowan
Hi
yes I use Mapped network drive but we use those for more that 3 years now. Never had any particular issue.
I m actually chatting with Qnap technical to find the issue. All pointing to nas issue
AS I try To copy all data to a simple PC and re run 3dsmax Scene, and it was all OK , 500 Mo scene + 3.3 Go proxy/maps/hdri.
I kept you update If I find anything, but seems an Acces file error as answered before
back from many days of test, logs files, exchanges, answering with Qnap Support.
And guess what, It is not there problem…
So here is copy of last exchange.
  1. Files can be edited from multiple clients simultaneously using Corona Rendre, which means SMB functionality is no problem.
  2. Corona Rendre doesn’t calculate the correct result via SMB, but it’s not software supported by QNAP,
    So if the customer wants to use Corona Rendre with share, this is a feature request.
Any clue ? Might have wait for a move from you guys or just Use custumer support where I buy Qnap, and exchange it with a Synology…
Sorry for lack of response.
If this is still a problem or if someone else experiences a similar thing, please let us know.
