Distributed Rendering over the Internet
I often work from home and the office. Would DR work over the internet? Let say I’m at home on my PC could I use DR with the Office PC?
Not sure how the asset handling would work. If transferring of missing assets works in this situation, it might take a long time to transfer :slight_smile:
I’ve always archived my file, sent it over to the office, and setup DR on a work machine to have it all render there. Then download the final image.
I tried it with amazon render farm. Did not work too well 5 years ago… I dont think anything got better since :- )
I did this for years. I simply used Chrome Remote Desptop and ran my office computer from home.
I think he want to send scene from his own PC and use Slaves at work rather than remote control his PC at work.
Yes, for Backburner and DR.
I figured, but why? If you are using the resources on the other side, why not have it all live there?
I would mirror the textures drive (maybe use an external and map it to the same letter) and work from home, then zip up the max files, transfer them over using remote desktop to render them in the office while continuing to do work on your home machine.
Max files compress down to under 5%, if you dont need to transfer assets you’re looking at 20-30mb transfers tops. more if you make a proxy or maps at home but if it’s client comments and changes you should be able to work pretty quickly like this. DR doesnt really work over a network, and letting it automatically transfer maps and stuff is not worth it.
I dont even bother mirroring a drive - i’ve worked on scenes at home with none of the maps able to load, assigning materials then sent it back to render in time for monday morning.
A few reasons, my power bill will go up and also my my employer just got me a 17,000 dollar PC I dough they will let me take it home.
It would be nice be able to work my home office and use that new Dual Xeon 28 Core machine as the muscle.
That sounds good. could I use Backburner to send the scene? I know it compress and zip the file to the Manager.
The size of scene dont matter if u mirror all and so on. The problem is network latency, ping and so on.
never tried. I drop the max file on google drive, open remote desktop, grab the max file and just press render. maybe switch on dr for the other machines in the office with it.
can keep doing other things on my home machine and check in periodically that way.
-mirror assets
-work with xrefs and copy your files to your office network
-the file that you want to send using backburner has only cameras, lights and xrefs so it’s very small and easy to send it over the Internet
if you want to change or update the model because you have xrefs only you have to send the updated xrefs and from BB you re-start the view and you are done.
Thanks! I plan to mirror assets on both PC’s and use backburner does anyone know how to configure my home PC to connect to Backburner at the office?
I would really appreciate if anyone can point me in the right direction.
Thanks!
I haven’t tried it yet, but this seems interesting (I think it has English language switch inside the software):
https://www.youtube.com/watch?t=453&v=Mys5JSNv8L8
I think this software allows you to send your file over the internet directly to your renderfarm (or workstation) to render the scene automatically without all the remote desktop, zip and unzip stuff. The concept looks very similar to rebusfarm solution, your scene and textures get uploaded to the server and then can be submitted to render on renderfarm via internet, once finished I think your final image can be downloaded.
I use hamachi for a virtual network, every computer will have an IP for that new VN then at home you use the new ip for the BB manager and for vray licenses if you need it.
regarding Matador if I remember well is Maxwell base rendering system… you upload the geometry and they have their own library material and assets.
This sounds interesting, how did you configure it, have you actually tried to render something over the internet without remote desktop?
So for example, do you see your render nodes in the bb monitor over the internet?
Yes, you can see the render nodes … It works exactly like you are at your work place. Make sure that you set the ip of the bb manager when you send it and inside of bb monitor as well…having a VN also allows you use Microsoft remote control if you want… But again you have to use the IPs of your VN. To transfer files and control my nodes from home I use logmein ignition, I can turn on computers remotely if at least one of the computers remains ON.
all you need is a vpn network to your office and you can then work at home and use vray (dongle) over the vpn network. you could also render and use distributed rendering… but this is slow as mentioned before…
best regards
themaxxer
