Do the Rhino and Max Vray Spawners Conflict?
Can I have both running at the same time? Seems that DR doesnt work unless I sop the service on the Max Vray spawner.
-T
Re: Do the Rhino and Max Vray Spawners Conflict?
No you can’t (sorry). You will need to shutdown the Max spawner before you start up the Rhino spawner. We are working w. the ChaosGroup to find a solution to this.
At this time all the V-Ray DR code uses the same ports regardless of what application is running them. So unfortunately this makes a race condition - whoever grabs that port first wins and the other is unable to grab work. We have contacted CG about providing us a solution and we should be able to have something workable by our next service release. Sorry for the inconvenience.
