Does anyone know a way (or if it’s even possible) to have the DR spawner for Rhino run and work while the DR Spawner for Max is also running?
We use both programs with a high level of frequency and wanted to run both spawners on our slave machines so that when if we needed to render in Rhino it would work and once it was finished we could run it as a DR spawner for Max without having to log-in, turn one off and turn the other on?
Any thoughts or help would be greatly appreciated!
The spawner used by V-Ray for Rhinoceros and Sketchup default to port 20211. The most recent Rhino, and future Sketchup, release let the user change those ports, but the default is still the same.
Thanks! I have had troubles when we tried it here but will double check to make sure that everything is set up correctly and try it again! Will definitely keep you updated. Thanks for the quick response.
