Dome light issue
OK this is odd.
I simply have a dome light with directional light for shadows in the scene.
You can see in the image that the treeline runs over the geometry when it should be occluded.
If I turn reflection of of the material it’s fine but as soon as I turn it on it seems as though you seen see through it like if you had turned refraction on or transparency. (Refraction is OFF)
Thanks for any help.
Unfortunately I can’t share anything here.
Latest Maya 2022.3 latest VRay release.
Standard material with metalness/glossness
Seems theres a bunch of domelight bugs that have cropped up in the latest release
It’s not a bugggg!
I found out that the VRayPlacementEnvTex node was set to Screen and not spherical.
