Dome light matte shadows issue
Flickering matte shadows coming from a simple Dome light( no map) ,in a simple scene, a plane and a teapot, Gi not GI the same result .I thing its a bug not happening in previous versions..Latest Vray ,3ds max version 2024 .
Hi, thanks for posting. Are you rendering animation? What are you using, GPU or CPU? What are your 3ds Max and V-Ray versions? Could you send us a video of the flicker?
The matte shadows have always had a bit more noise compared to the rest of the image. Please check this recent thread about it.
Hi, I am not able to reproduce this issue. Are you using default render settings? If not try to reset them. Please share the scene here or through the support contact form for review if you can’t manage on your own.
https://drive.google.com/file/d/1y-B…ew?usp=sharing
Here is the max scene.
In the “Image sampler” section of the V-Ray settings, turn on the option “Lock noise pattern”. This should stop the flickering.
Thanks so much Vlado, that was it.)) I thought that the lock option was for smaller scale noise.
Best.
Andreas.
Yes, it is related to the noise pattern but the matte/shadow calculations are a bit weird and cause some minor correlations between the random numbers to show up in unpredictable ways. I haven’t yet figured out a good way to resolve this; it might be a good idea to try again soon.
Is the issue related to this post and the fix is the same?
Best regards
Oliver
https://forums.chaos.com/forum/v-ray-for-3ds-max-forums/v-ray-for-3ds-max-problems/76023-flickering-in-alpha-with-matte-shadow
