I know this issue has been posted before, but I’ve found no solution to what is going on in my scene.
Lots of small dots are rendered in specific locations of the scene, even when indirect illumination is turned off. I asume it’s a material problem.
I found out that when hiding glass or water objects those dots disappear.
Some possible workarounds I’ve tried with no success are:
- no GI caustics
- vray environment override off
- displacement off
- perspective view render
I’m working with vray sun/vray sky/phisical camera with camera correction.
Merging the scene into a new file is not an option, cause I have my geometry linked to a DWG file.
Here are a couple of images with the problem showing and the settings I’m working with.
1. Try clicking sub-pixel mapping in the mapping rollout.
2. check for coplanar faces. (an STL check should show this… or use edit poly, select a face with the dots, and delete it to check that there aren’t two faces coplanar)
Sub-pixel mapping had no effect, there are no coplanar surfaces, I’m not using any color correct plugin, making the sun invisible didn’t work also, but lowering the multiplier from 0.9 to 0.3 or so did help. there still are some dots though.
I am not sure which type of camera correction you are using, but from my experience the one that is built into max/viz doesn’t play well with VRay.
*EDIT* I believe that if you change your view directly from a camera corrected camera to a perspective, your viewing angle will still be distorted. I would set up a different camera that does not have max/viz camera correction.
These dots are visible even with GI turned off, so it seems that it’s not GI caustics.
MAX-comp shade didn’t solve it.
I’ve been playing around with no success. I even isolated the object, turned off lights, changed camera, use a new material (standard vray with 0.5 in glossy and full refraction… Only when I untick vraysun from max’s environment some difference is made.
This dots seems to come from reflections/refractions.
Are there any messages in the VRay log window during rendering?
If a lot of your geometry is from a linked AutoCAD file it could be bad UVW mapping on something or if you’re linking an ADT file it could be a stray architectural material.
