double whitepoint/kelvin
forgive if i post in the wrong thread .. just want to ask, when i activated “Devel/Debug” mode, there will be 2 numbers value for whitepoint and whitebalance, which i think this must be related in 1 value only, you can try to change both of them and you will get different result ..
please see my attached image .. maybe any suggestion from all of you here .. :smiley:
thanks Rawalanche .. noted .. :smiley: now i know the value which will be the “primary” then .. :smiley:
the one in debug/devel can be used if you want to save your image with different whitepoint for some point. It works just as an inverse of the one in postprocessing.
noted Keymaster .. thanks :slight_smile:
