DR for PC master osx slave - change license settings on osx
Hi all,
how do you run the setvrlservice on osx ? tried dragging it to a terminal etc but its not clear on how i enter the IP address for the PC that holds the license
thanks and regards
ignuf
hi all again,
sorry found the setvrlservice but not sure how to run or configure it , tried dbl clicking , tried dragging it into a terminal etc but keep getting command not found .. any pointers please ?
in a terminal, cd to /Applications/Autodesk/maya_version/vray/bin, run this:
./setvrlservice --> this will print the help for the setvrlservice
./setvrlservice -dump --> this will print the current settings
./setvrlservie -server=<ipaddress> -port=<port_number> --> this will set the primary server to a new one (without the “<” and “>” symbols)
ah ! did it !
so in a terminal you enter $ sudo ./setvrlservice -server=192.***.***.*** -port=30304
enter your password and then press enter
(***.***.*** is the correct IP address for your license server )
thanks so much Alex !!
