Is there an updated xml file available for Design 2011, as there was for 2010? On all slaves, spawner is running, Max scene opens, but then closes again. Keeps re-opening and shutting. I see no error messages in Vray except opening and closing then saying server is not available…until it reloads again. Using Max Design 2011 HF4, Vray 1.5 SP5. Please advise, I’m ready to pull my hair out!!!
Read through all other threads but only saw a fix for 2010. No solutions for Design 2011.
Hi Vlado,
Yes I ran backburner on the machines successfully completing an scanline rendered animation. And I am running spawner with administrative rights. I have only found xml files for 2010 on the forum. Can you please attach the 2011 one? Thanks.
Problem SOLVED! I removed the Vray RT from my active shade window and left it as default scanline, and as for the licensing issue, From the Windows Start menu, in the “Change Vray client license settings” I replaced “local host” with the IP of one of my machines that has a dongle on it.
