I m a newbie with Corona
I am testing Corona DR, I sent 2 job on the 2 different machines, and each machine should pick up a render node from the server but instead one machine pick all the nodes.
Please let me know how I could resolve it?
Many thanks
https://kostenlosepornoshier.com - hardcore xxx videos for free
Maybe you had ticked “Search LAN during render” in “Render Setup” → “System” → “Distributed Rendering”?
Good Luck
Can you explain what exactly is happening? I think a simple drawing could help.
Generally, Corona’s DR will pick any node on LAN where the DR server is running. On the workstation, you can select which specific nodes to use (in Render Setup > System > DR).
