DR on MAX 8 9 2008 (maya cinema and others)
hiho
imagen you have max7 + 8 + 9_32bit + 9_64bit + max_2008 installed
to ensure a propper and error free DR I need to start the releated vrayspawner
in the exapmle abouve we have 5 different spawner
imagen cinema maya and xsi will be supportet (anytime)
then we have again several spawner to manage
@vray staff
I deam of an vray tool that listen on port X until a DR command appears and start the releated spawner
a little .cfg or .ini to spot the appl. paths and we all save trouble
impossible dream?
too far from realyty?
It is certainly possible and we’ll probably implement it at some point; when the DR spawner was originally implemented, neither V-Ray for Maya nor any other V-Ray version except the one for 3ds Max was in sight :slight_smile:
