Please check the Max servers parameter in the DR setting window. It should be set to “0”.
Could you also post or send us the full V-Ray log from the Main machine and one of the problematic render nodes.
Does the issue persist if Backburner is not involved in the rendering process?
Update: Everything works as expected in my test, even if I start the V-Ray spawner (manually and as a service) in the middle of the BB job.
If it happens again, please send us the log files and step by step instructions for recreating the setup.
Is that with the same environment of max design 2014 SP5 and v-ray 3.10.01?
This seems to happen every time a render node is powered up in the middle of a job. I have a log for the host machine I will email it to support quoting this thread.
Thank you, it will be very helpful to see this log, because usually there are the errors or warnings, which are not available in the host machine log.
I will post here if we manage to reproduce the issue.
Managed to reproduce the issue here. It seems that the DR broadcasting is broken and I will send a report to our developers about it.
Could you please confirm that the issue in your environment occurs only when the Spawners has been started after the renderer?
