Render node won't start
As of lately I’ve been having this strange issue with one new render node. It’s a dual E5-2695V3 (56 threads total).
V-ray spawner is installed as a service (as it is for all the other machines).
On a first render it picks up just fine, but on every next render (same session) it reports “not responding” and after a while it picks up at “Scene loaded, starting render” but it never actually starts the process.
Sometimes it reports no warnings at all, but it still hangs on “Scene loaded, starting render”.
The only solution is to restart the spawner service after every render.
This issue is most frequent if I cancel an ongoing render.
Is DR still bound in any way to the Bacburner? This is the only machine that doesn’t run backburner server by default.
I cannot find any reason other than that or perhaps the CPU core count for this issue to occur.
Does that behavior occur on every scene, try to render an empty scene with very high Min Subdivs for the Image Sampler to slow down the rendering so all the participants will be able to join.
Does the Restart Server on render end option resolves that issue:
Does it happen only if Spawner is starts as windows service? Try to start it manually and see if the issue is still there.
DR is bound to Backburner and it is necessary to run at least one BB job on the machine in order to work correctly with V-Ray DR, did you run that BB job or not?
