can you make it so that when you drag drop a vantage file in vantage, a dialogue should appear to ask you if you want to open the scene or to use as configuration only.
The same way as when you drag drop vrscene , it asks if you want to open , merge or place
Hi, thanks for the suggestion. We’ve logged it as a feature request (internal tracker LAV-1884).
