dubbel sided material
Hey I’m doing my first interior and I want to do my lamp cover with a double sided material so it shines a bit through.
How should I make this (I want some effect like curtains). I should just make a single face lamp cover and apply my texture to it.
Then I make a double sided material and apply my material to both sides and check the box below it?
Is it this simple?
Re: dubbel sided material
It’s almost that simple, but after you’ve created the front and back face materials and loaded them in the slots of the 2 sided Material you apply the 2 sided Material to both sides of the lampshade. It’s very counterintuitive; in fact once it’s all set up the front and back face materials aren’t actually applied to any geometry so you have to be careful not to purge the skp file or those materials will be deleted and your 2 sided Material will be “broken”. For this reason I always add a couple of rectangles hidden away somewhere in the model with the front and back materials applied to them so the materials can’t be purged by accident.
I do similar. I apply the original material to the edges of the object, and the VR2Sided to the faces. I purge all the time, it’s on a hotkey and I activate it religiously.
oke thnx for the tip
oke 2 other things:
1st I can’t get the uv-tool to work with the backside of the face. This is a cylinder.
2nd Does backfaces work correctly?
What UV tool? A plugin? Or SU’s texture tool?
your UV toolkit… on the font side of the cylinder it worked perfect but not on the backside
And what isn’t working? Transferring UV mapping from the front to the back?
Can you post the component in question?
yeah I will in a few min… another thing is I see it doens’t render in vray correctly.
In Sketchup it looked fine
V-Ray does not render distorted textures correctly. You can only scale them.
But if it’s a plain cylinder - it should not require distorted textures… Think we’ll just have to see the model.
this model I try to render correctly with double sided material on it:
http://rapidshare.de/files/48710961/wandlamp\_kap.skp.html
Well, I had no problem transferring the Front Face UV mapping to the Back side…
I just selected all the faces and used UV Toolkit → Frontface to Backface
How are you doing it?
(I’ll look at the rendering part next.)
BTw, you had 7 groups/components with material applied to them. That KILLS parsing time.
Yeah I selected all back faces and did apply cylindrical map. Thnx for that
yeah it’s a warehouse model… I know
It’s is not my plugin that maps cylindrical. that’s Whaat’s UV Tools plugin.
You can’t select “backface” - you can only select a face.
I suspect that Whaat’s plugin only applies Uv mapping to the front side. Then you can afterwards use my plugin to transfer the mapping from the front to the back - using the method I mentioned earlier.
But the problem still remains: VfSU doesn’t render distorted textures. So you have to map it yourself manually - making sure you don’t distort the texture, only scale them.
uuh I never done that… could give me an explaination.
I guess I have to set “show hidden geometry” on… and then with the eyedrop select and paint?
Yes, rotate and scale the first face to fit how you want it. Then sample that face and paint the next. Sample the one you just painted and repeat.
The problem is getting the texture to meet all the way around if you really want that. But, real lap shades rarely have the pattern meet perfectly all the way around. Usually there’s a seam where the start and end of the cylinder meet.
