i would like to create an visible edge around people billboards. Vrayedge doesn´t work as there is no geometry edge. vrayedge also doesn´t react on displaced edge using vraydisplacement to clip the geometry. Somebody knows the trick?
Matthias
hmmm, works with vraytoon but - somebody knows how to create shapeborder from bitmap without unsing environent effect/post?
Matthias
Hello there,
Could you please post a few examples of what do you want to achieve - a sample scene would be even better.
Thank you very much in advance.
I think what he is saying is that he wants to render the 2D billboard people like this 3D people example in the 1st post:
http://www.chaosgroup.com/forums/vbulletin/showthread.php?69957-VRaytoon-Thinks-Scene-Objects-Have-Been-Deleted
In that post it seems to be 3D people, but would be nice if we could do same effect for 2D billboard people
Yes exactly. Using 2D People billboards and Creating a Black outline. I Managed it with vray displacement and clipping, Creating The outline with vray toon. But for many billboard People That is Not very elegant.
Matthias
why not just map it ?
ok maybe a bit long, but works;)
Because with a render effect like VRayToon its “a click of a button”. Mapping it requires changing all your people maps which will take forever
