I have a VFB that isn’t updating the effectsResults. It jumped to it and after I toggled to RGB and back, it stopped updating.
Turning off hardware acceleration and forcing an update worked, however, that’s for bloom/glare. The VFB isn’t updating for the Denoiser either.
Check what is the post effects rate set to under system. If it’s 0, it will only update at the END of the render
Try setting it to 10 for more updates in between
Nope, it is set at 10. I have moved on, so I’ll see if it happens in this new project.
Which V-Ray version is this? Can you reproduce this behavior on a simple scene?
If you use bucket rendering, the effectsResult will update only after the entire image is complete (or you change some lens effects setting). It should update regularly when using the progressive sampler though.
Yes, that was it, thanks.[quote=“vlado, username:vlado”]
[/quote]
