Hi!
VFB always jumps to effectsResult RE when I switch to another image stored in the VFB history. But that element doesn’t exist on all images, so a wrong image gets shown. It should just show the beauty, of course.
Do you by any chance have the lens effects in the VFB enabled? effectsResult is a new channel we recently introduced to show the result of the lens effects. Even if the next image you load doesn’t have that channel, it will get created when the lens effects are enabled and they will be applied to the next image you load. See if that helps.
I use the denoiser. Not all the time, though. For simple tests I don’t want the denoising, so I toggle it off and then the problem occurs. Also the effectsResult is the same as the denoiser RE, when I don’t use other lens effects, right? Maybe that’s not the smartest way to go. But maybe it’s just temporarily in the nightlies?
