Enable button of a light doesn't work with a cloner
first of all, great that you can use now lights with a cloner and multi instances!
Not a problem, just a hint. The light stays enabled when unchecking the enable box of a light.
But, just with a cloner and multi instances…
Hello @haniel1107
I was unable to replicate the behavior you are describing.
Can you please share an example scene where the issue is present, and provide me with the exact V-Ray and Cinema 4D version you are using, and your OS?
You can find the V-Ray version at V-Ray > Help > About > right-click the text and select the copy text option and paste it here.
Hi @valentin_leondiev , I am using R25 and the latest nightly of Vray.
Attached a file and screenshots… Thanks
Light MI.zip (68.3 KB)
Hello @haniel1107
Thank you for the scene. I have logged the issue into our internal bug tracking system. (bug number: VC4D-1212) I will notify you when the issue has been resolved and a build with the fix is available for download.
