Switched off VRayLights, in geomtry group inside a RailClone object, still renders
Hi Guys
Not sure if issue on vray side or railclone side.
If I use vryalights, grouped, as source object in railclone, everything works as expected. You can adjust the multiplier etc.
However, if you untick the light in vray light lister to switch it off/disable it, it still renders
Thanks for the report. I’ve logged the issue (internal bug-tracker id: VMAX-12361). You can work around it by setting the color to black.
