Dear Vantage team,
Vantage is an amazing tool both for animation , but perfect for still archviz images.
It is very intuitive the fact that you can work in real time with really high resolution on the viewport, and click copy and paste the final render in ps to furher enhance it. This ctrl+C crtl+V thing from vantage to photoshop is amazing, and contributes unbelievably to the daily workflow of archviz image maker,
It would be fantastic if you can bring the render elements in the viewport , the same way you brought material override for instance, So that we can access the different render elements while we are on the viewport, copy paste what we need and bring it to photoshop, (if this will decrease frame rate , make it so that you enable it with a slider,)
Even more important is a black and white mask of selected object that generates as fast as I described above, This will help tremendously our work and workflow, cause very often you want to just edit a part of the image.
A cryptomatte render element will also be very useful
Thank you very much
Hi, thanks for posting. The request is logged in our system under LAV-1321.
