Hello do you plan to add Vray Enmesh and Decals (3d) to vantage at some point?
Hi Martin,
It is in the TO DO list but not a priority at the moment. Support for them would come at a much later stage.
Alexander
Ok thank you!
I just like to +1 Decal support.
I was going to ask the same as would help me no end !!! would it be early next year do you think ?
Is enmesh still not supported in Vantage?
Hi Luma3d,
Yes, enmesh is still not supported and cannot give an estimation when it will be. I will try to raise the priority.
Alexander
there is a need for vray blend material together with enmes
+1 for enmesh in Vantage. That would be dope !
Also +1 for enmesh. Currently using Chaos Scatter as an alternative, which is not ideal for some situations.
Hey guys,
Can you also vote in the Chaos Vantage Idea portal here for the enmesh support as well https://chaos.com/ideas/vantage/​VANTAGE-I-36 ?
Thank you!
Alexander
