Hm we will check the pattern, that should not happen. The outlines however are specified in “image pixels”, the larger your image resolution, the finer the outlines.
The weird thing is that even if I do an export with ‘window’ as resolution the outlines still look off.
I think the outlines in the preview window look great, so anything you can do to make them match better when exporting would be greatly appreciated. Any chance you can scale them up together with the image resolution so they look consistent with the preview window?
Strange, the first left table shows a fat edge in low res and no edge in highres. Should not happen and can’t explain by thinner outlines, since the fat lines should still be visible as thin lines like at other areas of the image.
If you’re creating stills, a workaround would be to render toonlines in skp using Vray…just add vraytoon as an effect, set a vraylight texture as your override and, whala…lines only which then can be comp’d in PS.
