I have downloaded the new 2.7 Version and it is not working. Enscape will not load.
It just remains on the ‘Loading’ screen and does not progress.
Welcome to our forum! Would you please be so kind as to install the Visual Studio 2015, 2017 and 2019 Redistributable? Installing this update should resolve the issue. Please be sure to install the x64 version.
Please get back to me if that doesn’t resolve the problem!
Thanks Demian
That solved the problem.
Very much appreciated:thumbsup:
Glad to hear that, thank you for the feedback. ![]()
Had the same issue here, installing the Visual Studio redistributable has solved the issue. Now to push it out to everybody…
I have an issue where Enscape 2.7.0 is not beeing loaded in to Revit 2020 at all? It is not in my window menu any more…i fixed it by using manual install and had to chose to install for all users on server. Manually pick Revit version.
Installing it for all users is the solution I was about to propose to you - glad to hear you were able to resolve it beforehand.
I have downloaded and installed both the new Enscape 2.7 as well as the Visual studio update (using the link above) and it is still not working for me, I still get stuck at 5% loading.
We had the same Issue. Enscape stuck on “loading” for forever. We uninstalled it and reinstall the 2.6 version and it worked perfectly.
So there must be bugs in this 2.7 version. Please fix as soon as you can so we can work in the latest and greatest version! ![]()
In this case, would you please be so very kind to either disable the any of the following software and/or deny the autostart when you boot your operating system if one of these is installed on your machine:
Asus Sonic Studio II
Alienware Sound Center
A-Volute
MSI Nahimic
Can you then let me know whether or not this resolves the issue for you?
If you have any other issues or questions, please don’t hesitate in getting back in touch.
Have you tried the solution above? If that doesn’t help, you can also try the solution I shared in this post - if afterward you’re still not successful, please send in a feedback report so that we can troubleshoot the cause behind this!
Have reinstalled Visual Studio from link above with no success. I additionally do not have any of the applications above. Any other ideas?
I’m sorry to hear about that - in this case please send in a feedback report as described here. In the submission form, you can also kindly include a link to this thread for reference.
Hi @Demian_Gutberlet , I am also having a similar issue after updating Visual Studio and Enscape is still stuck loading at 5%. I am using Rhino 6 instead (couldn’t find a thread related to Rhino) which gave me this feedback report:
2020.11.01 22:39:34.037 -08:00 [1] | INFO | Start Enscape …
2020.11.01 22:39:34.896 -08:00 [RenderWindowHostThread] | INFO | Starting Enscape
2020.11.01 22:39:36.220 -08:00 [RenderWindowHostThread] | WARN | API Error: Enscape_Initialize_From_Plugin: Enscape is not initialized
2020.11.01 22:39:36.222 -08:00 [RenderWindowHostThread] | INFO | Enscape started - elapsed: 1325ms
2020.11.01 22:39:36.224 -08:00 [RenderWindowHostThread] | ERROR | A.cc77781d40e3eda2bf3c15f7961fed0a1: Error on Enscape Initialize
at A.c5dc70fa8e76921af4b8d26c6cac91b2b.Start(c5607c4cfa630d65f33cfabf2b7f53a63 startupParameters)
at Enscape.Gui.Renderer.RendererWindowManager.TryCreate(c5607c4cfa630d65f33cfabf2b7f53a63 startupParameters, IntPtr& handle)
at Enscape.Gui.Renderer.RendererWindowHost.InitializeRendererWindow()
ApiResult: ca132ae7a1e8166a7f00854501ee3ce41
Any help on this would be appreciated!
I solved the problems by reinstalling old drivers (from nvidia) the ones from july 2020,
the lattest drivers make the V 2.9 stuck
hope It will work for you, (I have a Geforce 2080Ti. )
