Enscape 4.0 not loading in Revit 2024
I can’t get ensccape 4.0 to load into revit 2024
Hi @myoudall , in this case allow me to share the following which should help here:
In a situation where you do not see any reference to Enscape in any of the CAD’s menu’s or toolbar options, it is likely that the installation is corrupt or was somehow unsuccessful. In such circumstances it would be recommended to perform a fresh reinstall of Enscape. This means, uninstalling Enscape completely, rebooting the machine, and then running the Enscape installer again. You should also refer back to the installation steps, found here.
If that makes no difference for whatever reason please kindly get back to me after following the instructions above.
