Installed Enscape 4.0 and the tab does not appear in Revit 2024. Tried all the suggestions from Enscape but didn’t work. I had to install the 3.5.6 version again. Please resolve this issue. Thank you
I just came to report the same. I thought maybe it was moved to another tab like “Add-Ins” but no such luck. I’ve restarted, updated .net framework for the asset editor and everything else I can think of but Enscape is nowhere to be found.
An interesting side effect btw, my wallpaper went away on my desktop when I installed 4.0, like maybe there is a graphics card driver issue.
Very odd. I updated Revit to 2024.2 as well as Autodesk identity manager and the Autodesk License Installer. Still no Enscape so I uninstalled Enscape 4.0, restarted, reinstalled, then I had the Enscape Tab in Revit. BUT, now a bunch of the utilities that I had in the system tray such as Google Drive for Desktop, My audio controller, etc. are all gone.
same issue here - have just reinstalled 3.5.6 and the tab is there no issues
this is really poor
Quindi mi sconsigliate aggiornmento a 4.0?
Mi sembra assurdo oppure è successo solo ad alcune persone. Cosa vi ha risposto Enscape Team?
I believe the latest update has resolved the issue. If you check the version history, you’ll notice that two versions of 4.0 were released within a day of each other. I had the same issue with the 4.0.0.577 version, but not with the 4.0.0.579. Cheers!
thanks i just tried v 579 - downloaded, restarted and still no enscape tab in Revit! back to 3.5.6 for now…
might be time to learn Twinmotion which is free with Revit
Really? sorry ![]()
Yeah, I can’t wait to start using Twinmotion too. I have to admit that Enscape is more user-friendly, but everything becomes a habit with more usage.
totally agree!
TBH I really like Enscape and am reluctant to learn something new.
I’ve played around with TM and really don’t like the UI and workflow with Revit. It seems to have a few more enhanced features (weather / atmosphere / puddles / leaves / vegetation / material replacement generally) but maybe not enough to make the jump just yet…
Run the installer again and uninstall.
After uninstall, right-click on the installer and select Install as Admin.
thankyou - that worked!!
It shouldn’t be that hard - previous versions worked just running the installer.
(under advanced options it had all platforms selected by default - I deselected all except Revit - not sure if that had anything to do with it?)
I don’t think the uninstall / reinstall as admin is intended workflow. Perhaps something slipped through QA and will get fixed in future installer.
Thank you very much! That worked for me
I installed Enscape latest version 4.0.1.48 and it works with Revit 2025.
Thank you
olá tudo bem? como resolver a ativacao do enscape 4.0 no Revit 2025?
Welcome to our Forum. As detailed above in this thread please also try uninstalling Enscape once more and then re-running the installer as administrator:
In case you are not the administrator of your machine please refer to them accordingly for assistance.
Should that not do the trick or you are unsuccessful generally you can also reach out to our dedicated support team via our Help Center as detailed here.
Translation:
Bem-vindo ao nosso Fórum. Como detalhado acima neste tópico, tente também desinstalar o Enscape mais uma vez e, em seguida, executar novamente o instalador como administrador:
Execute o instalador novamente e desinstale.
Após a desinstalação, clique com o botão direito do mouse no instalador e selecione Instalar como administrador.
Caso você não seja o administrador da sua máquina, consulte-os de acordo para obter assistência.
Se isso não fizer o truque, você também pode entrar em contato com nossa equipe de suporte dedicada através de nossa Central de Ajuda, conforme detalhado aqui: How do I contact Support?
Yes this worked thank you!!
