Enscape Executables VR
Hello, i have a question about the exe file that you can export from enscape does VR work in oculus quest 2 ? and if not what are the supported headsets for VR
The executable is for windows only,
Enscape Supports Steam VR and Windows Mixed Reality headsets - any of the headsets that support these will work
@Ahmed_Sabrah , what Adam above me stated is correct.
In addition to that you can also check out our KB article for VR headsets here - The Quest 2 is also a device we can recommend to be used with Enscape either wired or wirelessly. Make sure to acquire or use a dedicated machine that meets our VR system requirements here as well and be aware that if you plan to use the Quest 2 wirelessly, you’ll also need a capable router for that.
