Enscape for Sketchup - Rendering Sections
Hi everyone, these images are rendered using sketchup section activated. I’m thrilled with this possibility!
Wow that’s a really cool way of doing figure ground. Awesome!
Yeah, it is really useful! Thanks!
wow this is very good !
nice balance between light and shadows !
yes, nice renders and views Indeed :thumbup: :thumbup:
@Pablo Correa - “these images are rendered using sketchup section activated” - what you mean here is that you can create those “theater-stage”-views this way instead of looking for any “real” in-model camera location? The black darkening of the cuted edges you made in postpro later?
only one coment ,
under bed there is a light
i know why but u can easily fix it with one single rectangle with black color inserted sligthly inside the bed object just to generate shadow …
I’ve done this way:
Yes, the cutted edges were made on photoshop.
Great advice, thanks!
I’m too, but Enscape 2.3.2.3 :slight_smile: SketchUp 2018 pro - 06/2018
:thumbup: a great (and actually so obvious :wink: ) suggestion which I will keep in mind for the next opportunity - thank you!
I really love this style of presentation. the custom lights and the color palette are fantastic as well. i do now also hate the light under the bed and cannot unsee ;). The TV is too bright as well but very cool overall!
Right now I can’t unsee it as well hahah thanks!
It’s okay Pablo, I have a light under my bed so it’s fine.
If you use the Skalp PlugIn with SketchUp, sectionfill works fine.
..but is there a way to avoid shadows from the cutaway geometry?
I never test like this. Love this tip…
I’m not sure if it could work cause I haven’t tried it yet but maybe if you make an additional rendering using draft mode then mixing it on photoshop. I’m saying that because on draft mode these light effects that are causing shadows are off. If you try please tell us if it works!
Even though it is helpful when showing internal lighting there should be an option to turn off shadow of the cutaway when showing planviews.
If you make a flat plane of (grouped) 3x3m rectangular lights with a quite high luminosity and place it just above the cutting plane, then it should light up everything.
(Using a large rectangle with an emissive texture won’t work - however if you create this group it can be easily hidden or put on a layer to toggle it on/off)
I know there are workarounds, -but shoudn´t be necessary. Other software does this, -but then the otherway -cannot do it like Enscape does which is also a nice feature ; ) Both choices please!
awesome render..wow… please can you share setting preset? since enscape save the file outthere so we can share it together
