Enscape Models not rendering with VRay
Just installed vray & updated Enscape. I notice that Vray is not rendering any of the Enscape assets from the standard Enscape model library. Is there anything in particular i should be looking for ? I tried it so far on two computers, neither will work. Sketchup 2022. Latest versions of Enscape & Vray as of Nov 21 2022. thx
Never mind - it just became apparent that it only works with VRAY after you have rendered it with Enscape first.
As you have correctly noticed, this is currently the right way to go :slight_smile:
Assets become visible in V-Ray after they are rendered once in Enscape. This is necessary and related to the way Enscape operates. The workflow needs to be repeated for each new Enscape asset that is added to the project.
Once the project is rendered with V-Ray, saved, then later closed, and reopened, V-Ray will have saved the necessary plugin data and all the Enscape assets should render correctly.
In addition, Enscape 3D People, unfortunately, are not supported by V-Ray.
A full list of unsupported assets can be found here
