Enscape not showing in taskbar or in Windows > Palettes
Hi all
I work at a University so we will be deploying Archicad (as well as the other softwares) and then enscape via a task sequence.
The other applications are working fine, however the enscape option in the taskbar and in windows > palettes is not showing for me when I open archicad.
I have tried a restart, opening several times - no difference made. I can see all the necessary Archicad/enscape add-on files in program files though.
It seems to work if I open Archicad first, before installing enscape, but this isn’t ideal.
If anyone has a better way to make it work so I can just push out archicad and then enscape, it would be appreciated.
To note I am using Archicad 24, and Enscape 3.0 Review 2
@DanGra96 , thanks a lot for your report and welcome to our Forum!
First off, it should be worth trying to install Enscape for all users as described here:
https://enscape3d.com/community/blog/knowledgebase/getstarted/#advanced_single
Also, please make sure you’re using our latest release as well, which is Enscape 3.1:
How can I make sure that my Enscape is up to date?
If that doesn’t help, please get back to me again.
@Demian_Gutberlet
I have been installing for all users, and I have just tried using 3.1 - getting the same issue annoyingly!
Hi @DanGra96
In case you haven’t already done so, could you send in a feedback report via the Enscape Feedback Button.
Please add a link to this thread in the description for reference.
Hello I have the same problem. I install Enscape, and it doesn’t appear on ARCHICAD 27…
